Transfer Speed Not Reflecting as Specification
Applied models:
All NAS Series
Applied Firmware:
All QTS Firmware Versions
If you encounter situations where the connections speed is not reflecting the speed as per specification of the devices, you may want to confirm if the switch support a specific transfer speed, as not all 10G switch supports 5G connection. For example, a switch may sup.
