[Thông báo bảo mật quan trọng] Phát hiện các trang web giả mạo Qfinder Pro. Tìm hiểu thêm >
How to avoid sudden shutdown from power outage?
Last modified date: 2026-01-06
Applicable products
  • All QNAP NAS models
Root cause
A sudden loss of power can stop your NAS from safely saving data to its storage devices, which may lead to data loss or file system corruption.
Solution
  1. Use a compatible UPS: Connect a compatible uninterruptible power supply (UPS) between your NAS and the power outlet. This allows your NAS to shut down safely during unexpected power interruptions.
  2. Configure UPS settings: Set up your NAS to detect power loss and perform an auto-shutdown in Control Panel > System > External Device > UPS.
  3. Check file system if a sudden shutdown occurs: After an unexpected power loss, check your volume status. If the file system is "not clean," run a file system check via Storage & Snapshots > Storage/Snapshots > select your volume > Manage > File System Check.
  4. Back up your data regularly to prevent data loss in case of unexpected events.
Further reading
57% of people think it helps.
Bạn vẫn cần hỗ trợ?
Hãy đăng câu hỏi của bạn trong Cộng đồng QNAP. Nhân viên QNAP và những người dùng giàu kinh nghiệm sẽ trả lời.
Hỏi Cộng đồng
Chọn thông số kỹ thuật
      Xem thêm Thu gọn
      Chọn quốc gia hoặc khu vực của bạn
