[Viktigt Säkerhet meddelande] Falska Qfinder Pro webbplatser har upptäckts. Läs mer >
How to avoid sudden shutdown from power outage?
Senaste ändringsdatum: 2026-01-06
Applicable products
  • All QNAP NAS models
Root cause
A sudden loss of power can stop your NAS from safely saving data to its storage devices, which may lead to data loss or file system corruption.
Solution
  1. Use a compatible UPS: Connect a compatible uninterruptible power supply (UPS) between your NAS and the power outlet. This allows your NAS to shut down safely during unexpected power interruptions.
  2. Configure UPS settings: Set up your NAS to detect power loss and perform an auto-shutdown in Control Panel > System > External Device > UPS.
  3. Check file system if a sudden shutdown occurs: After an unexpected power loss, check your volume status. If the file system is "not clean," run a file system check via Storage & Snapshots > Storage/Snapshots > select your volume > Manage > File System Check.
  4. Back up your data regularly to prevent data loss in case of unexpected events.
Further reading
Var den här artikeln till hjälp?
Användare som tyckte detta var användbart 57% procent.
Tack för din feedback.
Behöver du fortfarande hjälp?
Ställ din fråga i QNAP Community. QNAP-personal och erfarna användare svarar.
Fråga communityn
Berätta för oss hur vi kan förbättra artikeln:
Ge oss fler synpunkter genom att skriva dem nedan.
Välj specifikation
      Visa fler Färre
