How to connect to QIoT Suite Lite using MQTT?
In this tutorial, you will learn how to connect to QIoT Suite Lite using MQTT.
Refer to the following tutorial to learn how to connect different development boards to QioT Suite Lite: https://www.qnap.com/go/how-to/tutorial/qiot-suite-lite
Refer to the following link to learn how to establish IoT Application and Things: https://www.qnap.com/go/how-to/tutorial/article/how-to-show-dht11-data-on-qiot-dashboard
Open IoT Applications to get MQTT settings
  • Open your IoT Applications and go to your Things.
  • Click the "Connect a Device" button.
  • Choose "MQTT" and click "Next".
  • Click "Download JSON file". The name of file will be "resourceinfo.json".
"username": "c08b5979-1f8f-42da-9085-d761707be65c",
"myqnapcloudHost": "Not Available",
"clientId": "rpi2_1509005726",
"host": [
"172.17.28.73"
"password": "r:e91d53d57729b9d0b59772f9f2a130dc",
"port": 21883,
"resources": [
"description": "",
"datatype": "Float",
"resourceid": "temp",
"topic": "qiot/things/admin/rpi2/temp",
"resourcename": "temp",
"resourcetypename": "Temperature",
"unit": "°C"
  • Reference:
    1. "host" : The NAS IP
    2. "myqnapcloudHost": If you connect the myqnapcloud DDNS services on your NAS and it will provide a Internet hostname that can connect to QIoT Suite Lite. If your encounter issues with ports, then refer the following article: https://qiot.qnap.com/blog/en/2017/09/21/solve-problem-using-different-port-qiot-suite-lite-v1-0-41/
    3. "port": The MQTT port.
    4. "clientId": Devices identifiers.
    5. "username": The MQTT username.
    6. "password" : The MQTT password.
    7. "resources": Information of resources, including the following:
      • description: QIoT resource description.
      • datatype: QIoT resource data types.
      • resourceid: QIoT resource identifiers.
      • topic: The MQTT topic to publish and subscribe.
      • resourcename: QIoT resource names
      • resourcetypename: QIoT resource type names.
      • unit : QIoT resource units.
  • Type of Connection:
    "Connection":
    • Username : <username>
    • Password : <password>
    • Client ID : <clientId>
    "Publish":
    • Topic : <topic>
    • Payload:
      • {"value" : <data>}
    "Subscribe":
    • Topic : <topic>
Datum vydání: 2017-11-16
Bylo to pro vás to užitečné?
Děkujeme vám za vaši zpětnou vazbu. Máte-li nějaké dotazy, kontaktujte prosím adresu support@qnap.com
