What is the difference between Hybrid mount and VJBOD cloud?
Laatst gewijzigd op: 2022-06-24
Applicable Products:
  • All NAS series with QTS or QuTS Hero system
Alongside the HybridMount file-based gateway service, QNAP NAS also supports the VJBOD Cloud block-based cloud storage gateway service to optimally fulfill your requirements in versatile use cases. You can refer to the comparison figure below for the differences.
Was dit artikel nuttig?
67% van de mensen vond dit nuttig
Bedankt voor uw feedback.
Kies specificatie
      Toon meer Minder
