How to set up a UniFi Controller in Container Station?
Last modified date: 2019-03-27
  1. Open Container Station, go to the "Create" page and search for “UniFi”.
  2. Find the “jacobalberty/unifi” image and click “Create”.
  3. Select the image version and click "Next" to open the "Create Container" configuration wizard.
  4. Give the container a recognizable name (this example uses "UniFi_Controller") and configure the CPU and memory limits for the container.
  5. Go to "Advanced Settings" > "Network" and set the container to Bridge Mode.
  6. Click "Create".
  7. Go to the "Overview" page and open the UniFi_Controller container. This will start the UniFi Setup Wizard.
  8. Select the devices to configure and use with your UniFi Controller container.
63% of people think it helps.
