QVR Pro Client & QVR Smart Client System Requirements
Last modified date: 2023-02-13
  • QVR Pro Client
  • QVR Smart Client
QVR Pro Client/QVR Smart Client is a client software of QVR Pro server that can view images of QVR Pro, QVR Center, and QVR Elite.
QVR Pro Client is available for Windows andmacOS and QVR Smart Client is available for QNAP HDMI™ Display.
Attaining smooth performance when using QVR Pro Client or QVR Smart Client relies on the hardware and software capabilities of the Windows, macOS or QNAP device you are using.
This document presents the test results of recommended hardware specifications and how many channels they can support at what resolution and framerate.
1. Minimum requirements
Host NAS
A QNAP NAS capable of running QVR Pro or QVR Elite. QVR Pro Client or QVR Smart Clientconnects to this NAS to view the camera live stream and playback.
Windows
  • Windows 10 64-bit
  • OpenGL 3.2
Mac
  • macOS High Sierra 10.13
QNAP HDMI™ Display (QVR Smart Client)
  • NAS with HDMI™ output
  • QTS 5.0
  • QVR Smart Client Licenses
2. Tested Hardware Specifications
Windows
Integrated GPU
CPU Intel® Core™ i5-7500
RAM DDR4 2400 16GB
OS Windows 10 Pro 64Bit
Network 1GbE
Display Resolution 1920x1080
GPU Intel® UHD Graphics 630
Discrete GPU
CPU Intel® Core™ i7-9700KF
RAM DDR4 2666 16GB
Network 1GbE
GPU NVIDIA GeForce RTX 2060 6GB
Mac
Integrated GPU(Intel)
Specifications - MacBook Pro (13-inch, 2017 ,Two Thunderbolt 3 ports)
- Intel Core i5
- 16 GB(Customized)
OS macOS Big Sur
Display Resolution 2560x1600
GPU Intel® Iris Plus 640(Integrated)
Integrated GPU(Apple M1)
Specifications - MacBook Pro(13-inch, M1,2020)
- Apple M1 chip
- 16 GB (Customized)
OS macOS Big Sur
GPU Apple M1 (Integrated)
Discrete GPU
Specifications - iMac (Retina 5K, 27-inch, Mid 2015)
- Intel Core i5
- 16 GB(Customized)
OS macOS Big Sur
Display Resolution 5120x2880
GPU AMD Radeon R9 M290 with 2GB of GDDR5 memory
QNAP HDMI™ Display (QVR Smart Client)*
Model TVS-872XT-i5-16G
OS QTS 5.0
* No Recording - The QNAP HDMI™ Display only runs QVR Smart Client and its dependent HD Station, without installing other applications that consume more hardware resources (for example: without installing QVR Pro Server)
* Recording - The QNAP HDMI™ Display with 16 channels (CH)recording at the same time only runs with QVR Pro Server-recording 16CH, QVR Smart Client and its dependent HD Station, without installing other applications that consume more hardware resources.
The test method of this article
  1. Use the hardware of each platform to connect to QVR Pro. Under the condition that the normal load of the CPU or GPU is less than 80%, play the specified stream and calculate the maximum number of playable channels.
  2. The type of camera used during these tests was the VIVOTEK IP9167-HT. The Group of Pictures (GOP) setting was 30.
  3. In practice, the bitrate setting, streaming format, and overall available network bandwidth of each IP camera may affect the actual playback and display performance. The test results in this article are for reference only.
3. Test results comparison
Video Test Spec Format H.264 H.264 H.264 H.265 H.265
Resolution 720P 1080P 1080P 720P 1080P
Throughput 2Mbps@30fps 6Mbps@15fps 6Mbps@30fps 2Mbps@30fps 6Mbps@30fps
Support Display Channels Windows Integrated GPU 41 CH 35 CH 19 CH 47 CH 16 CH
Discrete GPU 52 CH 52 CH 26 CH 50 CH 44 CH
Mac IntegratedGPU (Intel) 10 CH 7 CH 5 CH *11 CH *5 CH
Integrated GPU (M1) 38 CH 43 CH 20 CH *52 CH *24 CH
Discrete GPU 17 CH 18 CH 12 CH *19 CH *11 CH
NAP HDMI™ Display TVS-872XT(No Recording) 56 CH 60 CH 34 CH 56 CH 38 CH
TVS-872XT(Recording 16 CH) 58 CH 60 CH 34 CH 64 CH 35 CH
*macOS currently does not support H.265 hardware decoding. These test results are based on using software decoding.
77% of people think it helps.
