How many subfolder and subdirectory limitation on NAS (QTS system)?
Last modified date: 2022-06-24
Applied Products:
  • All NAS Series
  • All QTS Firmware Versions
The NAS QTS uses EXT4 file system format, which has a limit of 64000 subfolder, provided there are still inode available for use. The subdirectory limitation was base on the path length, allowing up to 256 ascii characters.
50% of people think it helps.
      Chat with us! Chat with us!
