How can I start using myQNAPcloud Storage?
Last modified date: 2024-01-11
 myQNAPcloud Storage
Procedure
After signing up for a QNAP ID, you can instantly get a free cloud storage space.
myQNAPcloud Portal
  1. Go to www.myqnapcloud.com
  2. Sign in with your QNAP ID.
  3. Select myQNAPcloud Storage from the left menu.
  4. Click Create Space.
  5. Select a region where you want to store your data.
  6. Click Subscribe.
You can then go back to the myQNAPcloud portal and starting using the cloud storage.
HybridMount (1.11.4008 or later versions)
  1. Click Create Remote Mount in Mount Management.
  2. Choose to create File Cloud Gateway or Cloud Drive Mount.
  3. Select myQNAPcloud Storage from the cloud service list.
  4. Sign in with your QNAP ID.
  5. Click Search, and then click Get Free Space if you have never got a free space with this QNAP ID.
  6. Select a region where you want to store your data.
  7. Click Subscribe.
  8. Follow the on-screen instructions to complete the setup.
HBS 3 Hybrid Backup Sync (22.0.0511 or later versions)
  1. Create a Backup or Sync job.
  2. Select myQNAPcloud Storage from the Cloud Server list.
  3. Sign in with your QNAP ID.
  4. Click Get Free Space if you have never got a free space with this QNAP ID.
  6. Click Subscribe.
  7. Follow the on-screen instructions to complete the setup.
40% of people think it helps.
Still need help?
Ask the Community
