Difference between Mustang-F100 and Mustang-V100.
Last modified date: 2019-01-31
If you are focusing on video processing only, we highly recommend you Mustang V100 which features low power consumption. If you need to process audio and signal at the same time, Mustang F100 would fits your demand.
50% of people think it helps.
