TS-239 Pro II Specification
CPU | Intel® Atom™ Single-Core processor |
DRAM | 1GB DDRII RAM |
Flash Memory | 512MB DOM |
HDD | 2 x 2.5"/3.5" SATA NOTE:
HDD Tray | 2 x Hot-swappable and lockable tray |
LAN Port | 2 x Gigabit RJ-45 Ethernet port |
LED Indicators | Status, LAN, USB, eSATA, Power, HDD 1, HDD 2 |
USB | 5 x USB 2.0 port (Front: 1; Back: 4) Support USB printer, pen drive, USB hub, and USB UPS etc. |
eSATA | 2 x eSATA port (Back) |
Buttons | System: Power button, USB One-Touch-Backup Button, Reset button |
Alarm Buzzer | System warning |
Form Factor | Tower |
Dimensions | 150 (H) x 102 (W) x 216 (D) mm 5.91 (H) x 4.02 (W) x 8.5 (D) inch |
Weight | Net weight: 1.74 kg (3.84 lbs) Gross weight: 2.92 kg (6.44 lbs) |
Sound Level (dB) | w/o HDD installed: 33.3 dB Stand by: 33.7 dB In operation: 34.2 dB (with 2 x 1TB HDD installed) |
Power Consumption (W) | Sleep mode: 15W In Operation: 22W Power-off (in WOL mode): 1W (with 2 x 1TB HDD installed) |
Temperature | 0~40˚C |
Humidity | 0~95% R.H. |
Power Supply | Input: 100-240V AC, 50/60Hz, Output: 60W |
Secure Design | K-lock security slot for theft prevention |
VGA | Reserved VGA interface for maintenance |
Fan | 1 x smart fan (7 cm, 12V DC) |
Powerful All-in-one server |
