Data Integrity Check in HBS 3
Last modified date: 2021-05-12
Important:
This feature is available in HBS 3 v16 and later.
Data Integrity Check is a feature in HBS 3 that analyzes your backups and attempts to repair any corrupted data.
Due to the dynamic nature of most files, there are many opportunities for your data to become corrupted. This corruption might be intentional or unintentional. Intentional corruption might be caused by malware or human actors. Unintentional corruption might be caused by software, hardware, power, or network failures.
To reduce the chances of losing your data, QNAP recommends adopting a 3-2-1 backup strategy (Keep three total copies of your data, Store two copies on different media, Store one copy off-site). Additionally, you can use data integrity checks for extra security.
How Data Integrity Check Works
Data integrity checks compare your backed up data to the original files and attempt to determine if any corruption has occurred. HBS 3 offers two types of data integrity checks: quick check and content check.
Tip:
Data integrity checks require significant system resources and may take a long time to complete. For the best processing speed, QNAP recommends using an x86-based device with SSDs.
Feature
Quick Check
Content Check
Method
Compares the existence, size, modification time, and/or hash value of each file
Uses one of the following methods:
  • Compares the existence, size, modification time, and hash value of each file
  • Downloads all files and calculates hash values for comparison
Supported Jobs
Created in HBS 3 v16 or Later
All backup jobs except NAS-to-NAS jobs with QuDedup disabled
All backup jobs
For NAS-to-NAS jobs, if the destination NAS runs HBS 3 v15 or earlier, only jobs with QuDedup enabled are supported.
Created in HBS 3 v15 or Earlier
None
Supported Cloud Destinations
HBS 3 currently supports all cloud destinations except the following:
  • Amazon Glacier
  • Amazon S3 Glacier Deep Archive
  • Azure Archive Storage
Quick Check
Quick checks require fewer system and network resources than content checks, while still ensuring a basic level of data integrity.
NAS-to-NAS Backup Jobs
NAS-to-Cloud Backup Jobs
QuDedup Disabled
QuDedup Enabled
Unavailable
The following metadata are compared for each file:
  • File existence
  • File size
  • Modification time
  • File existence
  • File size
  • Modification time
  • Hash value (if provided by the cloud service)
For jobs where client-side encryption is enabled, hash values are also recorded and compared.
Content Check
Content checks provide a more thorough analysis of data integrity than quick checks, but may require significantly more system and network resources to perform.
Because data can still be altered without changing the file size or modification time, comparing hash values or file contents is a more reliable method to detect data corruption.
Important:
To perform content checks, you must enable Content Check from the Data Integrity Check screen when configuring the backup job. For details, see the Hybrid Backup Sync documentation.
  • File existence
  • File size
  • Modification time
  • MD5 hash value
If the HBS 3 version on the destination NAS does not support data integrity checks:
  • Jobs with QuDedup disabled are not supported.
  • For jobs with QuDedup enabled, files are downloaded temporarily and hash values are calculated for comparison.
Files are downloaded temporarily and hash values are calculated for comparison.
Important:
This may result in additional fees from your cloud service provider.
After you enable Content Check for the first time, HBS 3 will continue to record MD5 hash values even if you disable it later.
Running Data Integrity Checks
You can run data integrity checks manually, or configure scheduled checks when creating a backup job.
Frequency
Quick Check
Content Check
Manual checks
  1. Open HBS 3.
  2. Go to Backup & Restore.
  3. Select an existing backup job.
  4. Click Check Data Integrity.
  5. Click Quick Check.
  1. Open HBS 3.
  5. Click Content Check.
You must enable Content Check in the backup job configuration in order to run a content check.
Scheduled checks
For details on configuring quick check and content check schedules, see the Hybrid Backup Sync documentation.
Data Corruption Repair
When performing a data integrity check, if HBS 3 finds that any files have been corrupted, it will attempt to repair those files automatically at the end of the check.
Important:
Automatic repair is unavailable for NAS-to-NAS backup jobs with QuDedup disabled.
If version management is enabled for a backup job, HBS 3 also checks the data integrity of all backup versions where hash values were previously recorded. However, only data corruptions found in backup versions that are identical to the latest version can be repaired.
For example, suppose the most up-to-date backup is at version 5. If a file was updated only once in its entire history in backup version 3, and HBS 3 finds that version 2 of the file has been corrupted, HBS 3 would only be able to report the corruption but not repair the file. However, if HBS 3 finds that backup version 4 of the file has been corrupted, it would be able to repair the file because the file has remained unchanged between versions 4 and 5.
Schedule Conflict Policies
HBS 3 resolves schedule conflicts between a backup job and its data integrity check or data corruption repair depending on different circumstances.
  • While a backup job is running, HBS 3 skips all manual and scheduled checks.
  • If a backup job is scheduled to run during a data integrity check, the data integrity check pauses and resumes after the backup job finishes.
  • If a quick check and a content check are both scheduled to run at the same time, only the content check will run.
If a backup job is scheduled to run during a repair session, their schedules are resolved according to the job type:
  • Backup jobs with QuDedup enabled: The backup job is skipped until its next scheduled run.
  • Cloud jobs with QuDedup disabled: The repair is paused and resumes after the backup job finishes.
67% of people think it helps.
