How to Expand Capacity by Adding a Drive?
Last modified date: 2022-03-30
Applicable Products:
  • QTS 4.3.6 and later version.
  • Storage & Snapshots
It is possible to expand the capacity of a Static Volume or a Storage Pool by adding one or several drives to a RAID Group, or by creating a new RAID Group inside a Storage Pool.
Notes:
  • All existing data on the new drives will be deleted (data on existing drives will not be deleted)
  • Adding disks to a RAID 1 group changes the RAID type of the group to RAID 5
  • To expand a RAID 50 or RAID 60 group, every sub-group must be expanded with the same number of disks
  • If the storage pool contains a RAID 1, RAID 5, RAID 6 or RAID 10 group, when creating a new RAID Group, it must also have one of the mentioned RAID types.
How to expand a Storage Pool by adding a drive to a RAID Group:
  1. Go to Storage & Snapshots > Storage > Storage/Snapshots
  2. Select the pool and click on "Manage"
  3. Click on "Expand Pool" > "Expand Pool"
  4. Select "Add new disk(s) to an existing RAID group"
  5. Select the RAID Group to expand. The group must be of type RAID 1, RAID 5, RAID 6, RAID 50, RAID 60
  6. Select the disk and click on “Next”
  7. Confirm the settings and click on “Expand”.
How to expand a Storage Pool by creating a new RAID Group:
  4. Select "Create an add a new RAID group"
  5. Select the disks and RAID type and click on “Next”
  6. Confirm the settings and click on “Expand”.
How to expand a Static Volume:
  2. Select the volume and click on "Manage"
  3. Click on "Manage" > “Add Disk”
  4. Select the new hard drive member and click on “Apply”.
63% of people think it helps.
