How to set up Multimedia Console and AI Recognition Engines for use in Qsirch (5.2.0 or later)?
Last modified date: 2022-06-24
Applicable Products:
  • Qsirch
General Information
To provide AI-driven search functionality in Qsirch (5.2.0 or later) you must enable Multimedia Console and AI Recognition Engines.
Enabling Multimedia Services
  1. Log on to the NAS as an administrator.
  2. Open the App Center.
  3. Install Multimedia Console.
    Note: From QTS 5.0.0, Multimedia Console will not be automatically installed on your NAS.
  4. Open Multimedia Console.
  5. Enable Multimedia Services
    Important: In QTS 5.0.0 (or later) this option will not appear as Multimedia Services are always enabled when Multimedia Console is installed.Your Multimedia Services are running.
Enabling AI Recognition Engines
  3. Install and start QNAP AI Core.
  5. Go to AI Engines.
  6. Confirm that the Facial Recognition and Object Recognition AI Engines have the status of Completed.
    The AI Engines are ready to use in Qsirch.
25% of people think it helps.
