[Önemli Güvenlik Uyarısı] Sahte Qfinder Pro Web Siteleri Tespit Edildi. Daha fazla bilgi edinin >
Will trunking accelerate transfer speed?
Last modified date: 2022-06-24
Applicable Products:
  • Network&Virtual Switch
Port Trunking can increase bandwidth on a QNAP NAS . Click here for details.
But please note the following:
  1. Port Trunking cannot break the speed limit of a single Ethernet device, but it offers a sufficient amount of bandwidth for multiple users connecting at the same time. For example, if two 1Gb NICs are used for Port Trunking, the aggregated network bandwidth will be increased to 2Gb, but the network speed will remain 1Gb.
  2. Available system resources and the maximum read/write speeds of the storage devices on the NAS will greatly influence the overall bandwidth.
Daha fazla yardım için toplulukta diğer kullanıcılara ve QNAP uzmanlarına sorun. QNAP Topluluğuna Git
Teknik Özellik sSçin
      Daha fazla göster Daha az
      Diğer ülkelerde/bölgelerde bu site:
