NAS (QTS / QuTS hero)
Scenario
Some QNAP NAS models support both QTS (a modern app-based NAS OS with ext4 file system) and QuTS hero (an advanced, ZFS-based NAS OS). If you want to change your NAS operating system, this article explains how to safely switch from one to the other and highlights key benefits and considerations for each.
Solution
Switching from QTS to QuTS hero
Benefits of QuTS hero (ZFS)
- Data integrity and self-healing: ZFS provides end-to-end checksums that detect and correct data corruption, and supports copy-on-write snapshots.
- Efficient storage: Inline data deduplication and compression saves space.
Note: At least 32 GB RAM is recommended for optimal performance of these features. - Advanced protection and disaster recovery: SnapSync enables near-real-time, snapshot-based backup and disaster recovery across QuTS hero NAS devices.
- Large shared folder support: Single ZFS shared folders can be up to 5 petabytes (PB).
- WORM (Write Once, Read Many): Data can be locked against modification, supporting compliance needs.
Procedure
Important
Switching to QuTS hero will erase all data on your NAS. Make sure to back up your data before starting.
- Power off your NAS and remove all storage devices, including M.2 SSDs.
- Ensure your NAS is connected to the internet, then power it on.
- Sign in to the NAS. The QuTS hero Smart Installation screen will appear.
- Select QuTS hero under the Switch OS heading and follow the on-screen instructions to complete the installation.
- After installation, power off the NAS, reinstall your storage devices, and restart the NAS.
Switching from QuTS hero to QTS
Benefits of QTS (ext4/LVM)
- Qtier auto-tiering (QTS only): Automatically moves frequently accessed ("hot") data to SSDs and less-used ("cold") data to HDDs within the same storage pool.
- Lower system overhead: QTS runs efficiently even on NAS models with less than 8 GB of RAM, making it a good choice for entry-level hardware.
- Wide app compatibility: QTS supports a large selection of QNAP and third-party applications.
- LVM (Logical Volume Manager): Enables flexible volume and storage management.
Procedure
Important
Switching to QTS will erase all data on your NAS. Make sure to back up your data before starting.
- Sign in to the NAS. The QTS Smart Installation screen will appear.
- Select QTS under the Switch OS heading and follow the on-screen instructions to complete the installation.
Which operating system should I choose?
| Choose QuTS hero (ZFS) if you want... | Choose QTS (ext4/LVM) if you want... |
- ZFS self-healing, integrity and robust snapshots
- Data deduplication and compression
- Large single shared folders (up to 5 PB)
- SnapSync for disaster recovery
- WORM compliance features
| - Auto-tiering (Qtier for SSD/HDD in a single pool)
- Lower resource overhead on entry-level hardware
- Extensive QNAP app ecosystem
- Simpler, traditional NAS experience
- Recommended for systems with less than 8 GB RAM
Further Reading
Alkalmazható termékek
Forgatókönyv
Néhány QNAP NAS modell támogatja mind a QTS-t (egy modern, alkalmazásalapú NAS operációs rendszer ext4 fájlrendszerrel), mind a QuTS hero-t (egy fejlett, ZFS-alapú NAS operációs rendszer). Ha meg szeretné változtatni a NAS operációs rendszerét, ez a cikk elmagyarázza, hogyan válthat biztonságosan az egyik rendszerről a másikra, és kiemeli az egyes rendszerek fő előnyeit és szempontjait.
Megoldás
Váltás QTS-ről QuTS hero-ra
A QuTS hero (ZFS) előnyei
- Adatintegritás és önjavítás: A ZFS végponttól végpontig terjedő ellenőrzőösszegeket biztosít, amelyek észlelik és javítják az adatkárosodást, és támogatják a másolás íráskor Pillanatkép-t.
- Hatékony Tárhely: Az inline adat Deduplikáció és tömörítés helyet takarít meg.
Megjegyzés: Legalább 32 GB RAM ajánlott ezeknek a funkcióknak az optimális teljesítményéhez. - Fejlett védelem és katasztrófa-helyreállítás: A SnapSync lehetővé teszi a közel valós idejű, pillanatképalapú biztonsági mentést és katasztrófa-helyreállítást a QuTS hero NAS eszközök között.
- Nagy megosztott mappa támogatás: Egyetlen ZFS megosztott mappa akár 5 petabájt (PB) is lehet.
- WORM (Write Once, Read Many): Az adatok módosítás ellen zárolhatók, támogatva a megfelelőségi igényeket.
Eljárás
Fontos
A QuTS hero-ra való váltás törli az összes adatot a NAS-on. Győződjön meg róla, hogy biztonsági másolatot készít az adatairól, mielőtt elkezdené.
- Kapcsolja ki a NAS-t, és távolítsa el az összes Tárhely eszközt, beleértve az M.2 SSD-ket is.
- Győződjön meg róla, hogy a NAS csatlakozik az internethez, majd kapcsolja be.
- Jelentkezzen be a NAS-ba. Megjelenik a QuTS hero Smart Installation képernyő.
- Válassza ki QuTS hero az Operációs rendszer váltása címszó alatt, és kövesse a képernyőn megjelenő utasításokat a telepítés befejezéséhez.
- A telepítés után kapcsolja ki a NAS-t, telepítse újra a Tárhely eszközeit, és indítsa újra a NAS-t.
Váltás QuTS hero-ról QTS-re
A QTS (ext4/LVM) előnyei
- Qtier automatikus rétegzés (csak QTS): Automatikusan áthelyezi a gyakran elért ("forró") adatokat az SSD-kre, és a kevésbé használt ("hideg") adatokat a HDD-kre ugyanazon Tárhely poolon belül.
- Alacsonyabb rendszerterhelés: A QTS hatékonyan fut még olyan NAS modelleken is, amelyek kevesebb mint 8 GB RAM-mal rendelkeznek, így jó választás belépő szintű hardverekhez.
- Széleskörű alkalmazás kompatibilitás: A QTS támogatja a QNAP és harmadik féltől származó alkalmazások széles választékát.
- LVM (Logikai Kötetkezelő): Rugalmas kötet- és Tárhely kezelést tesz lehetővé.
Eljárás
Fontos
A QTS-re váltás törli az összes adatot a NAS-on. Győződjön meg róla, hogy biztonsági másolatot készített az adatairól, mielőtt elkezdi.
- Jelentkezzen be a NAS-ra. Megjelenik a QTS Smart Installation képernyő.
- Válassza ki a QTS-t az Operációs rendszer váltása címszó alatt, és kövesse a képernyőn megjelenő utasításokat a telepítés befejezéséhez.
Melyik operációs rendszert válasszam?
| Válassza a QuTS hero (ZFS) rendszert, ha... | Válassza a QTS (ext4/LVM) rendszert, ha... |
- ZFS önjavítás, integritás és robusztus Pillanatkép
- Adat Deduplikáció és tömörítés
- Nagy méretű, egyetlen megosztott mappák (akár 5 PB)
- SnapSync katasztrófa utáni helyreállításhoz
- WORM megfelelőségi funkciók
| - Automatikus rétegezés (Qtier SSD/HDD egyetlen poolban)
- Alacsonyabb erőforrás-terhelés belépő szintű hardvereken
- Kiterjedt QNAP alkalmazás ökoszisztéma
- Egyszerűbb, hagyományos NAS élmény
- Ajánlott kevesebb mint 8 GB RAM-mal rendelkező rendszerekhez
További olvasmányok
