Can I speed up my NAS by migrating the system volume to an SSD?
QTS
Details
No, migrating the System volume to an SSD won't significantly speed up the booting process unless you're replacing every drive with an SSD.
The QTS boot speed is influenced by the number of applications installed on the NAS. You can see some improvements by removing or disabling unneeded apps.
Additionally, some apps can operate faster if they are migrated to an SSD volume. You can check if an app supports this migration by right-clicking the app in the App Center and selecting Migrate to.
