Why does WOL not work on 2.5GB network port on TS-X31P3?
Last modified date: 2023-05-22
  • TS-x31P3 NAS Series
  • QTS Firmware 5.0.0 Versions and later
Limitations
Wake On LAN (WOL) is not supported on the 2.5 GbE network port for the TS-x31P3 series NAS model due to hardware limitations. However, the 1GbE network port does support the WOL feature.
Note: WOL functionality is not supported when combining 2.5GbE and 1GbE ports in a port trunking configuration.
80% of people think it helps.
เลือกสเปค
      ดูเพิ่มเติม น้อยลง
