최신 업데이트일:
2023-11-02
Hybrid Backup Sync
Workaround
- Create a new rsync storage space with Use encryption port enabled. Enter the IP address of the remote rsync server and use the Username and password of the remote rsync server that has SSH privileges.
- Create a new job and use this new storage space.
- Configure the same source and destination paths.
- Use the default job settings.
- Run the job.
Further Reading
아직 도움이 필요하신가요?
QNAP 커뮤니티에 질문을 올려 주세요. QNAP 직원과 경험 많은 사용자가 답변해 드립니다.
