Why does WOL not work on 2.5GB network port on TS-X31P3?
最後修訂日期: 2023-05-22
  • TS-x31P3 NAS Series
  • QTS Firmware 5.0.0 Versions and later
Limitations
Wake On LAN (WOL) is not supported on the 2.5 GbE network port for the TS-x31P3 series NAS model due to hardware limitations. However, the 1GbE network port does support the WOL feature.
Note: WOL functionality is not supported when combining 2.5GbE and 1GbE ports in a port trunking configuration.
這篇文章有幫助嗎?
80% 的人認為有幫助。
謝謝您,我們已經收到您的意見。
請告訴我們如何改進這篇文章:
如果您想提供其他意見,請於下方輸入。
