Manually Upgrade/Downgrade firmware by QTS web interface
Procedures
1. Find Control Panel > System > Firmware Update.
2. Click Firmware Update and Browse the img file on your PC/Mac , then Update System
3.Click OK if you want to upgrade/downgrade the firmware version.
4.Fimware uploading will start after clicking OK.
5.If the uploaded firmware version is older than the current firmware version, following prompt will pop.Please read them and check I have read the above and understand the risks of downgrading firmware if you want to proceed, click Update System.
6. Wait for firmware upgrading process finished.
Related links
추가 도움이 필요하시면 커뮤니티에서 다른 사용자 및 QNAP 전문가에게 문의해 보세요. QNAP 커뮤니티로 이동
