Smart Versioning for Snapshot Replica Does Not Delete Snapshots on Destination NAS
Last modified date: 2020-11-17
Applied models:
  • All NAS Series
Applied Firmware:
  • 4.4.1 or above
When creating snapshot replication to another NAS, with Smart Versioning configured. The smart versioning will only apply to the source NAS and remove snapshots on the source NAS according to the defined number configured, smart versioning does not apply to the destination NAS and will not remove the snapshots on the destination NAS. They will need to be removed manually.
