How can I reduce sync-related lag in Qfile Pro on my mobile device?
Last modified date: 2025-07-04
Qfile Pro
Solution
Qfile Pro currently does not provide a built-in option to limit sync speed or bandwidth usage. The synchronization performance is mainly affected by your mobile device’s hardware, system resources, and network quality.
During file sync operations, Qfile Pro actively uses:
  • Network bandwidth
  • Device CPU and memory resources
  • Storage I/O (read/write)
If your phone has limited processing power, is running many background apps, or is connected to a weak or congested network, you may notice system lag or slower overall responsiveness during synchronization.
Recommended Workarounds
To reduce potential performance impact during sync, consider the following:
  • Schedule sync operations during times of low network activity (e.g., at night or when not actively using your device)
  • Close background applications to free up RAM and CPU
  • Ensure a strong and stable Wi-Fi connection during sync operations
These actions can help improve overall system responsiveness while Qfile Pro is syncing files.
      Chat with us! Chat with us!
