What is meaning of led color on QHora/QMiro/QMiroPlus?
Data da última modificação: 2023-09-07
Applicable Products:
  • QHora
  • QMiro
  • QMiroPlus
  • For Qhora-301W LED status, you can refer to the following tables:
More details can be found on the QHora User Guide.
  • For QMiro-201W LED status, you can refer to the following table:
More details can be found on the QMiro User Guide.
  • For QMiroPlus-201W LED status, you can refer to the following table:
More details can be found on the QMiroPlus User Guide.
Este artigo foi útil?
Obrigado por seu retorno.
Escolher especificação
      Mostrar mais Menos
