Why snapshot from thin volume will cause storage pool oversubscription easily?
최신 업데이트일: 2022-08-19
Applicable Products:
  • Storage & Snapshots.
The Snapshots are directly saved on the available space in the Storage Pool. If you have configured Pool Guaranteed Snapshot space the snapshot will be saved in this space and will be retained reserved for snapshot files only.
Now if you have created a thin volume in the Storage Pool it will use space on-demand which means they take space from the Storage Pool only as data is written to the volume.
Oversubscription occurs when the data on the thin volume takes larger space capacity than the storage space allocated for the volume and the snapshot will back up the data which is the same size of the oversubscribed volume.
To solve this issue, you may try to:
  • Delete the old snapshots to free more pool space for taking the new snapshot or
  • Expanding the storage pool capacity
이 기사가 도움이 되었습니까?
100% 의 사용자들이 도움이 된다고 생각할 것입니다.
피드백을 주셔서 감사드립니다.
이 기사가 어떻게 개선될 수 있을지 말해 주십시오.
추가 피드백을 제공하려면 아래에 포함하십시오.
사양 선택
      더 보기 적게 보기
      다른 국가/지역 사이트:
