How to Build a High-speed Media Editing Environment for EDIUS Pro 9
About This Tutorial
Your QNAP NAS is the perfect tool to help create a high-speed media editing environment that integrates well with EDIUS Pro 9. Whether dealing with multiple projects, HD audio, or 4k video, your QNAP NAS can help you:
- Create a network drive to access NAS folders from your PC.
- Transfer files from your PC at lighting quick speeds.
- Import files stored on the NAS directly into EDIUS Pro 9.
- Instantly share files with clients or colleagues.
QTS Configuration
Shared Folder Mounting
- Creating projects on the NAS with EDIUS Pro 9
- Importing from the NAS to EDIUS Pro 9
- Exporting to the NAS from EDIUS Pro 9
QTS Configuration
In order to use your QNAP NAS to consolidate and store your media files, you must connect your PC to the shared folders on your NAS.
Configuring SMB 3
Editing Shared Folder Permissions
Qfinder Pro
Qfinder Pro can discover available QNAP NAS devices and shared folders on your network. Mounting a NAS shared folder as a network drive allows easy access and management of files from your PC.
To download and install Qfinder Pro for macOS, go to https://www.qnap.com/utilities/.
Mounting a Shared Folder to Windows 10
The shared folder is mapped as a network drive and can be accessed using Windows Explorer.
Mounting a Shared Folder to macOS
The shared folder is mapped as a network drive can be accessed using Qfinder.
Operating System
The shared folder is mapped as a network drive and can be accessed.
Creating Projects on the NAS with EDIUS Pro 9
An EDIUS Pro 9 project is created on the NAS.
The media files are imported into the EDIUS Pro 9 project.
The EDIUS Pro 9 project is exported to the NAS.
