Why the transferring speed in HBS is much more slow than the testing speed?
最後修訂日期: 2024-06-06
Hybrid Backup Sync
Details
The speed test was a quick check with the bandwidth, therefore the real transferring speed depends on both side resources, writing speed in target.
The "Total transferring speed" is an average value which will be dragged down if you are transferring many small files.
Just like you transfer 1,000 files with 10 MB each will get slower average speed than only one 10 GB file transferring in your PC/MAC.
You can click Details button to check the speed of single file.
If you want to do some speed test, try to set a sync job without any compression and encryption, sync just one big file about 10 GB which will be more precisely.
這篇文章有幫助嗎?
10% 的人認為有幫助。
謝謝您,我們已經收到您的意見。
還有疑問?
在 QNAP 官方社群提問,獲得 QNAP 官方與熱心用戶的第一手建議。
前往社群發問
請告訴我們如何改進這篇文章:
如果您想提供其他意見,請於下方輸入。
