How do I fix connection problems (collect QNAP NAS log/ QNAP NAS configuration, etc) when I monitor a QNAP NAS via myQNAPcloud address and change the Q'center LAN IP afterward?
Applied Models:
Answer:
Ensure that the new Q'center LAN IP is updated on myQNAPcloud and then check if the forwarded service port is changed (for example: 8080 > 8090).
If the port is changed, please modify the current Q'center IP/ Port at the QNAP NAS with Q'center Agent.
Release date: 2016-02-03
Was it helpful?
o
