How to keep the same number of files and folder in 2 synchronized Shared folder using HBS3
最終更新日: 2022-03-30
Applied models:
Applied Firmware:
  • All Firmware Versions
If you set up a synchronization Job in HBS3 from a source NAS to another remote NAS, It is possible that you see that the number of files and the number of folders (Control Panel > Privilege > Shared Folders) is different from in origin and remote shared folder, however the synchronization is running without errors and the content seems to be synchronized.
This is happening due the system generated temporary files. So if you want to prevent this, You just will need to uncheck “Exclude System-generated temp files” in the synchronization settings and it will display the same number of files and folders.
この記事は役に立ちましたか?
ご意見をいただき、ありがとうございます。
この記事の改善箇所をお知らせください。
その他のフィードバックがある場合は、以下に入力してください。
仕様を選択
      もっと見る 閉じる
      当ページを他の国/地域で見る:
