How does Qsync Pro work on iOS devices?
Ultima data di modifica 2023-05-10
Applied models
  • All NAS Series
Applied firmware:
  • All NAS firmware
Scenarios:
Why cannot iOS Qsync Pro sees folders in phone like computer client or Android version does?
Answer:
Due to iOS’ sandbox mechanism, an APP can only access folders within it; the APP cannot access to other APPs’ folders. Thus, when you set up paired folders in phone, they are folders in Qsync Pro. Here is an example,
When setting up a pair, I need to create a folder in Qsync Pro first. In the picture below, I create a folder named “Test”
After a pair is set, I can find the pair in Manage Paired Folder page like picture below.
Then, I can see there is a new folder “Test” created in Qsync Pro by sliding out the left panel and it’s synced with Qsync folder in a NAS
Once the sync paired is set, those 2 folders will be in sync following the rules that I set. For example, renaming a file in “Test” in Qsync Pro, the same file in the NAS folder “Qsync” will also be renamed automatically.
9% delle persone lo ritengono utile.
Grazie per il feedback.
Scegliere le caratteristiche
      Mostra di più Meno
