QNA-UC10G2T Specification
USB 4 Type C to dual-port 10GBASE-T adapter
Hálózati adapterek USB 4 to 10GbE Támogatja az Ubuntu kereskedelmi Linux disztribúcióit Ubuntu 22.04 Windows támogatás Windows 11 Standard Warranty 2 year PHY IC AQC113 I/O 1 x USB-C, 2 x 10GBASE-T connector Transmission rates 10Gbps/5Gbps/2.5Gbps/1Gbps/100Mbps Operating temperature 0-35˚C Package Contents QNA adapter, 1 x USB 4 C to C cable, manual Port és kábel RJ-45; Cat 6a cable recommended Note: QNAP reserves the right to replace partial parts or accessories if the original is no longer available from its manufacturer/supplier. Any replacement would be fully tested and verified to meet strict compatibility and stability guidelines and will deliver identical performance to the original.
