Why installation an application from App Center are too slow even internet/network speed has no problem?
Release date: 2022-10-06
Applicable Products:
  • App Center
Installation of any Application from App Center, either directly download or manually installed were too slow even the Internet connection or the network bandwidth are in normal or no latency.
  1. Check any warning in the disk.
  2. Check the System Volume system cache and enable that function if unchecked where the qpkg are stored.
  3. Check the Write Cache (EXT4 delay allocation) and enable if unchecked.
    By default, those functions are enabled.
    If the above steps are checked and still experiencing the slow performance, please run a performance test in your disk and contact QNAP Support.
20% of people think it helps.
További segítségért kérdezze meg a többi felhasználót és a QNAP szakértőit a közösségben. Irány a QNAP közösség
Válassza ki a specifikációt
      Mutass többet Kevesebb
      Írj nekünk! Írj nekünk!
