Issue with shutdown machines
Última fecha de modificación: 2020-10-15
Applied models:
Applied Firmware:
Please run hardware test procedure to confirm whether there is any hardware problem:
       Please confirm 2 parts:
  1. Do you have the original RAM?
  2. Do you have the original power cord?
       Then follow these steps to test and monitor what it shows /sounds
                1. Turn off the NAS
                2. Remove all hard drives from NAS and devices (ex usb, etc ..)
                3. Turn on the NAS without any hard drives- do you hear a short beep
                     after 10-15 seconds?
                      Yes  ⇒ please go to next  step, No => maybe there is hardware issue
                 4. After 3-5 minutes you should hear another beep, do you hear the
                     second beep?
                     Yes => please go to next step , No => maybe firmware (on MB) issue
                 5. Open Qfinder Pro, select your NAS.
                 6. Insert the hard drives again.
If the machine would start up to step 6 ,the hardware problem would be rare and please contact local support’s help to check more detail.
El 50% de las personas piensa que ayuda.
Gracias por sus comentarios.
Elija especificación
      Mostrar más Mostrar menos
