TS-859 Pro Specification
CPU | Intel® Atom™ Dual-core Processor |
DRAM | 1GB DDRII RAM |
Flash Memory | 512MB DOM |
HDD | 8 x 2.5"/3.5" SATA NOTE:
HDD Tray | 8 x Hot-swappable and lockable tray |
LAN Port | 2 x Gigabit RJ-45 Ethernet port |
LED Indicators | Status, LAN, USB, eSATA, Power, HDD 1, HDD 2, HDD 3, HDD 4, HDD 5, HDD 6, HDD 7, HDD 8 |
USB | 5 x USB 2.0 port (Front: 1; Back: 4) Support USB printer, pen drive, USB hub, and USB UPS etc. |
eSATA | 2 x eSATA port (Back) |
Buttons | System: Power button, USB One-Touch-Backup Button, Reset button |
LCD panel | Mono-LCD display with backlight Enter button, Select button for configuration |
Alarm Buzzer | System warning |
Form Factor | Tower |
Dimensions | 185.2 (H) x 298.2 (W) x 235.4 (D) mm 7.29 (H) x 11.74 (W) x 9.27 (D) inch |
Weight | Net weight: 7.3 kg (16.08 lbs) Gross weight: 8.6 kg (18.94 lbs) |
Sound Level (dB) | w/o HDD installed: 40.0 dB Stand by: 40.4 dB In operation: 40.8 dB (with 8 x 750GB HDD installed) |
Power Consumption (W) | Sleep mode: 30W In Operation: 59W Power-off (in WOL mode): 1W (with 8 x 1.5TB HDD installed) |
Temperature | 0~40˚C |
Humidity | 0~95% R.H. |
Power Supply | Input: 100-240V AC, 50/60Hz, Output: 350W |
Secure Design | K-lock security slot for theft prevention |
VGA | Reserved VGA interface for maintenance |
Fan | 2 x quiet cooling fan (12 cm, 12V DC) |
Powerful All-in-one server |
