IEI products
New things to buy from IEI Integration Corp.
HDB-301R
USB 3.0 Uncompressed Video/Audio Capture Box with One Channel HDMI Input and One Channel HDMI Bypass Output, 1920x1080@60p
HDB-301R
  • 1-channel HDMI input and 1-channel HDMI bypass output
  • Supports for 4:2:2 color spaces to provide the highest quality for your images
  • HDMI bypass output supports video no delay pass through up to 1080p60, so you can watch original video while video processing
  • Designed for professional video, machine vision, broadcast & post production industries
  • For audio mastering, 24-bit 48kHz audio provides the power you need to integrate into any audio environment
  • Supports DirectShow AP (VLC or AMcap)
  • Windows/Linux OS supported
» Learn more
Egomat
A Digital Mat for Health and Entertainment, Supporting Bluetooth to Work with Mobile Devices for Easier Control
  • Easy to carry and fold up
  • Bluetooth connection with mobile devices for walking and dancing anywhere, anytime
  • iOS and Android systems supported
  • PU material increases thickness and enhances non-slip capability. The surface is not easy to create wrinkles.
  • Complete exercise record: time, distances, steps and calories consumed in every dancing and walking activity will be recorded, and presented in graphic charts, making it easy to record users’ exercise history.
» Learn more
Egomat
IS-453S
4-bay Industrial NAS/NVR for Tough or Mobile Environments
IS-453S
  • Rugged design with high resistance to vibration and impact
  • Dust-resistant and fanless design
  • Wide operating temperature range: -40°C ~ 50°C (-40°F ~ 120°F)
  • AES-NI hardware encryption acceleration
  • Up to 221MB/s read and 214MB/s write speed with 2 Gigabit LAN ports
  • Complete solutions for file sharing, backup, disaster recovery, and data security management
» Learn more
TANK-860-QGW
Cloud Based IPC built-in QTS Gateway OS for IIOT
  • Built-in QTS Gateway operating system that can be visualized immediately
  • Supports remote connection (myQNAPcloud) and hybrid backup (Hybrid Backup Sync)
  • QRM+ easily monitors IPMI equipment, servers, PCs and production line equipment
  • Q’center centralizes management of multiple QNAP NAS and the IPC equipped with QTS Gateway
  • Surveillance Station for remote video surveillance, 24/7 security
  • Seven levels of data security protection to protect your valued data
» Learn more
Egomat
AFL3-W07A-BT
Intel® Celeron® N2807 (Dual Core, 1.58 GHz)
  • W7” ~ 8.4” light industrial interactive panel PC
  • 9 V ~ 30 V wide range DC input with lockable DC jack
  • Selectable AT/ATX power mode
  • Built-in speakers
  • One mSATA slot
  • IP64/IP65 compliant front panel
  • IEI One Key Recovery solution allows you to create rapid OS backup and recovery (suggested with over 4GB storage capacity)
» Learn more
Egomat
