How to Install QVR Pro Beta?
QVR Pro is a professional video surveillance management software that enables you to perform real-time remote monitoring, recording, and playback. It provides various management functions to help protect the security of your property, home, or office environment.
Important: Before running the QVR Pro Installation Wizard, make sure that your system meets the following minimum specifications.
Table 1. QVR Pro Server
Hardware / Software Version
NAS firmware 4.3.0 or later
Container Station 1.6.1588 or later
RAM 4GB
Note: Beta version is available only for TVS-x73 series.
Table 2. QVR Pro Client
Operating Systems Windows 7 SP1, 8, and 10
Mac OS X El Capitan 10.11.5
Recommended Web Browsers Google Chrome 52.0 or later
Mozilla Firefox 48.0 or later
Supported Display Resolutions Minimum: 1366 x 768
Maximum: 1920 x 1080
Online Installation
  1. From the QTS console, go to App Center > All Apps.
  2. Locate QVR Pro and then click Install.
    QVR Pro is successfully installed.
  3. Click Open.
    The QVR Pro Installation Wizard appears.
  4. Click Start.
  5. Review the Terms of Use.
  6. Select I agree to the QVR Pro Beta Terms of Use.
  7. Type your name and email address.
  8. Click Next.
    The wizard verifies that the system meets the minimum specifications.
  9. Click Next.
  10. Select whether to use the default directory location or specify a new location.
  11. Verify that the information is correct and then click Next.
  12. On the confirmation screen, click Back to modify the settings or click Next to proceed.
    Once the installation completes, you will automatically be logged into the QVR Pro console.
Offline Installation
  1. Go to the QVR Pro Beta website.
  2. Download the QVR Pro QPKG file.
  3. Connect to the NAS.
    1. From a web browser, type the following URL on the address bar: http://<NAS IP>:8080.
    2. From Qfinder Pro, locate and double-click the NAS from the list.
  4. Type the administrator login ID and password, and then click Login.
  5. Click the App Center icon on the desktop or from the main menu.
  6. Click the Install Manually button on the top right corner of the App Center screen.
  7. On the Install Manually tab, click Browse and then locate the QPKG file on your device.
  8. Click Install.
  9. Locate QVR Pro in the App Center and then click Open.
  10. Click Start.
  11. Review the Terms of Use.
  12. Select I agree to the QVR Pro Beta Terms of Use.
  13. Type your name and email address.
  14. Click Next.
  15. Click Next.
  16. Select whether to use the default directory location or specify a new location.
  17. Verify that the information is correct and then click Next.
  18. On the confirmation screen, click Back to modify the settings or click Next to proceed.
Release date: 2016-08-30
Was it helpful?
50% of people think it helps.
