How to access a Remote Desktop using SSH in QRM+
QRM+ provides multiple methods for using remote desktop functionality to access different devices:
  1. Windows devices: RDP or VNC remote desktop.
  2. Linux devices: VNC remote desktop or SSH connection (an SSH client program is not required).
  3. IPMI devices: KVM over IP remote computer management program.
Follow these steps to access a remote desktop using SSH in QRM+:
Step 1: Open a device in QRMAgent and click "Tools".
Step 2: Select "Remote Desktop" > "SSH".
Step 3: Enter the User Name and Password for the remote device in the Security Check.
Step 4: Click "Apply".
Step 5: The browser will open a new page. If the connection is successful, the remote desktop will be displayed. If the connection fails, an error message will be displayed and the user can try to reconnect.
Step 6: Press CTRL + SHIFT + ALT in the new browser tab to open the on-screen keyboard.
Release date: 2017-12-06
Was it helpful?
