How to configure hot spare disk for RAID in QES?
In QES system, as long as the disk is initialized and its status is READY, this disk will be treated as global hot spare disk. You don’t need to configure and assign which disk is hot spare disk but you need to reserve the disk whose status is READY to be a hot spare disk.
Ex: In the picture below, there is a RAID 6 (Disk5 - Disk15) group and Disk16 is the hot spare disk.
Release date: 2017-12-01
Was it helpful?
50% of people think it helps.
o
