Why does the remote control not work with the TAS-168/268?
Applied Models:
Answer:
Some Android apps do not support remote controls or keyboard. On apps like Kodi, every function on the remote control is supported for playback.
Please make sure the plastic film on the battery has been removed (refer to QIG) before using the remote control.
Release date: 2016-01-20
Was it helpful?
