QXP-W6-AX200
Upgrade to Wi-Fi NAS or Wi-Fi Windows®/Linux® PC by Adding 802.11ax high-speed wireless connectivity
The QXP-W6-AX200 is a PCIe Gen 2x1 Wi-Fi 6 wireless adapter with an Intel® Wi-Fi 6 AX200 module that supports the IEEE 802.11ax standard (backwards compatible with 802.11a/b/g/n/ac), MIMO 2Tx2R, MU-MIMO TX/RX and Bluetooth 5.0. The QXP-W6-AX200 can be installed in a QNAP NAS, or Windows®/Linux® PC to provide fast Wi-Fi 6 connection speeds. The QXP-W6-AX200 can also be used with Wi-Fi 6 router to deploy Wi-Fi 6 network environment. A full-height bracket is pre-installed on the QXP-W6-AX200 and two low-profile brackets are also included.
The QXP-W6-AX200 supports Wi-Fi 6 802.11ax, provides up to 2400Mbps connection speeds, and is backwards compatible with 802.11acR2/ abgn.
The QXP-W6-AX200 supports MU-MIMO 2Tx2R, providing greater connectivity with multiple clients; OFDMA increases network efficiency and decreases packet delay.
The QXP-W6-AX200 has dual band 2.4GHz/ 5GHz antennae, multiple angle tilt, and a magnetic base for the best signal strength direction and location.
The QXP-W6-AX200 supports BSS coloring that marks shared frequencies with a number for easy differentiation.
Bluetooth® 5.0 provides faster speeds and wider range to easily connect to multiple devices.
Notes: Bluetooth® 5.0 is only available when installed in a Windows® PC and requires an internal USB connection.Bluetooth® 5.0 provides faster speeds and wider range to easily connect to multiple devices.
Wi-Fi 6 uses 1024-QAM to provide a signal packed with more data, and enables 25% faster data rates than 256-QAM.
2.8x Faster Connectivity
The QXP-W6-AX200 dual band Wi-Fi 6 PCIe card supports 802.11ax 160MHz dual band connectivity, 1024-QAM and up to 2400Mbps connection speed which is 2.8 times faster than Wi-Fi 5(802.11ac).
Notes:
1. Wi-Fi speed and connection quality may vary based on network traffic, environmental factors, Internet speed, client device performance, and the number of other Wi-Fi and radio signals in the immediate area.
Easy Access with a Wireless NAS
With a QXP-W6-AX200 installed in your NAS, you can free yourself from Ethernet cables and access all your stored files and multimedia over a high-speed wireless connection. A full-height bracket is pre-installed on the QXP-W6-AX200 and two low-profile brackets are also included.
Notes:
1. System requirements: 64-bit x86-based NAS (Intel and AMD), or ARM-based NAS, with QTS 4.4.3 (or later) with a PCIe Gen 2x1slot. Check the Compatibility List for a full list of compatible NAS.
2. Some NAS models must update their BIOS to the following versions. You can download BIOS from the Download Center and learn how to update a BIOS here.
• TS-251B: Q015AR02
• TS-653B: QY59AR58
• TS-251D, TS-253D: Q04WAR08
• TS-453D, TS-653D: Q04MAR12
• TS-453DU, TS-453DU-RP, TS-853DU-RP, TS-1253DU-RP: Q05PAR03
