Why is there no sound when I play videos/music using the TAS-168/268?
Applied Models:
Answer:
Please confirm:
  1. Ensure that your TV and TAS-168/268 are not muted.
  2. Go to Android “Setting” > “Sound” and check if HDMI output is "Auto" or not. If it is set to "RAW" without being connected to a receiver, there will be no sound as there is no external decoder.
Release date: 2016-01-20
Was it helpful?
