Why does my QVM not have audio output?
Applied Models:
Answer:
Here is a list of compatible Operating Systems (OS) supported for QVM use.
OS list for QVM support*
Windows 7
8
8.1
Server 2003
Server 2003 R2
Server 2008
Server 2008 R2
Server 2012
Server 2012 R2
Fedora 12
13
14
15
17
18
19
CentOS 6.1
6.2
6.3
6.4
Red Hat Enterprise Linux 6.4
Suse Linux Enterprise Server 11
OpenSUSE 11.3
12.3
Ubuntu 12.04 LTS
12.10
13.04
13.10
*If you do not find your VM OS listed above, you may not be able to use this VM using QVM or you may not have audio support due to the lack of support for proprietary drivers.
If your QVM does not fit the output monitor, please refer to this link.
Release date: 2015-01-07
Was it helpful?
