Why does a system error occur when I try to open Surveillance Station after restoring system settings?
Applied Models:
Answer:
You must re-install Surveillance Station and reboot your Turbo NAS. Then you will be able to access Surveillance Station again.
Release date: 2014-09-04
Was it helpful?
