The Turbo NAS does not power on after I press the power button. What should I do?
Applied Models:
Answer:
Remove all the HDDs, make sure the power cable, power adaptor, and the power supply unit are connected correctly and the power supply is normal. If the problem persists, contact your local reseller or distributor for repair or replacement service.
Release date: 2013-04-19
Was it helpful?
16% of people think it helps.
