My keyboard or mouse does not work in Android after I reboot the TAS-168 /268. How can I fix this problem?
Some USB keyboards and mice have compatibility issues when the TAS-168/268 is rebooted. To fix this problem, disconnect and reconnect the USB device after Android has finished booting.
Release date: 2017-03-16
Was it helpful?
