Why can a QNAP NAS not join a domain using an RODC (Read-Only Domain Controller)?
Applied Models:
Answer:
QNAP NAS can only join domains using an RWDC (Read/Write Domain Controller). Join attempts will fail if the domain controller is not writable. This is a QNAP NAS limitation.
Release date: 2016-08-04
Was it helpful?
