Firmware on built-in flash, hard drive are not consistent
Last modified date: 2020-11-06
Applied models:
Applied Firmware:
  • Any
     If there is event related to firmware on built-in flash, hard drive/disks not consistent, it’s recommended to update the firmware to ensure system stability.
15% of people think it helps.
