Why is my QNAP NAS being incorrectly reported as offline? Why does my NAS display "Agent has problem"? Why does my NAS display "Q'center agent is abnormal"?
There are several possible causes for these issues:
| Cause | Fix |
| Your network firewall is blocking ports 6600, 6606, 6621 or 6623. | Configure your firewall settings. |
| Your network is heavily congested or has limited capability for handling multicasts. | Check your network and related router settings. |
| The IP address has changed for Q'center or the managed NAS. |
| Your NAS is not working normally and has caused the Q’center Agent to become unstable. | Disable the Q’center Agent
Reinstall the Q’center Agent
| Q'center Agent is unable to send or receive data normally because the managed NAS is under heavy CPU load (> 90%) or has limited network bandwidth. |
Still need help?
