Why does my QVM not have audio output?
Here is a list of compatible Operating Systems (OS) supported for QVM use.
| OS list for QVM support* | |
| Windows | 7 8 8.1 10 Server 2003 Server 2003 R2 Server 2008 Server 2008 R2 Server 2012 Server 2012 R2 Server 2016 Server 2019 |
| Fedora | 12 - 26 |
| CentOS | 6.1 - 6.8 7.0 - 7.4 |
| Red Hat Enterprise Linux | 6.4+ 7.0+ |
| Suse Linux Enterprise Server | 11 |
| OpenSUSE | 11.3+ 12.3+ |
| Ubuntu | 12.04 - 20.10 |
*If you do not find your VM OS listed above, you may not be able to use this VM using QVM or you may not have audio support due to the lack of support for proprietary drivers.
If your QVM does not fit the output monitor, please refer to this link.
