While running QuTScloud as a virtual machine, QuTScloud does not recognize newly added virtual disks. How can I resolve this problem?
Last modified date: 2020-09-24
This problem might occur due to one of the following reasons:
  • QuTScloud ignores disks smaller than 48GB. If any virtual disk is smaller than 48GB, you must expand it.
  • QuTScloud supports a maximum of 25 disks, which includes 1 system boot disk and 24 data disks. If you add more than 25 virtual disks, then QuTScloud will mount the first 25 and ignore the rest.
  • If you are using a hypervisor such as QEMU or Proxmox, check the SCSI Controller Type. The default type (LSI 53C895A) only supports 14 disks. To use more than 14 virtual disks, change the SCSI Controller type to VirtIO SCSI.
    For more information, see the Proxmox wiki.
Still need help?
Ask the Community
